HELP with Axle shaft
I'm needing some help with finding a axle shaft other than thru a dealership.
What I have is a 02 F150 with a 9.75 rear gear, 12 bolt pattern and 5 lug.(need the drivers side)
The number that is stamped on the axle is V919A.
This is where the problem is, no one other than a dealership has that number on file.
I've tried junk yards, ebay, rock auto and have came up with 0.
Rock auto has one that has all the specs that mine has, but that number does not match up with any of theirs listed.
Any ideas or suggestions would help.
You can visit the " find store " that is a list of axle shaft with a very cheap price.I also suggest to have time in road marker road marker .
on
If you search http://car-part.com all of USA you will find your V919A. BTW driver side is the left side for the search engine. It should be the 7th from the bottom.
