3.73 vs 4.10
3.73 vs 4.10
will i be able to tell a difference if i go from 3.55 to 3.73? i would like some low end improvement without compromising top end. i think the 4.10 will hurt my top end. is that a true statement?. Also, whenever i do the gears i am going to install Powertrax no slip unit.
thank you for any info.
Black 99 xlt sc flairside,4.6 2w.d.,jardine catback,
superchip,
RS9000 shocks,
lowered 2" front and back,svt rims,265/60/18 avs yokohamas,
Ford 9mm sparkplug wires.
Snug Lid.2 KC daylighters.
FUTURE MODS: LS AND 4.10 GEARS.
superchip,
RS9000 shocks,
Changing .25 or so is not real noticeable; .50 or so really starts to show a change. Either gear will get you toward your goal of low-end performance. Alot of people recommend .50 or more, since it requires a complete tear down, and tire changes can modify ratio easier. A gear change/tear down is the time to get the LS if it is a complete diff. The Powertrax Lock-Rite can be installed without diff removal. 4.10s still provide plenty of top end unless you want to run at very high speeds, especially if you ever get bigger tires.
2000 F-150 XL,RC,LB,5.4,4R70W,3.55LS,
Class III tow/Payload #3/Convenience pkgs.,
4-wheel disc/ABS,Chestnut/Parchment 40/60,
Ford bedliner & gas/wheel/spare locks,
3" cold air box modification, Superchip,
Dynomax ultra-flow welded 3" cat-back,
3" exit Y-pipe, Hellwig rear anti-sway bar.
20 years ago 4.10 and even 4.56 or greater were common -- and were pretty annoying when not towing.
Thanks to that marvelous overdrive gear added a dozen years ago - 4.10's are pleasant performance-enhancers -- and can really put that engine 'oomph' to the ground.
I agree with MM about making the modification noticeable if you're gonna do it at all.
I barely notice the difference between my 3.73 and a 3.55 in my '97 -- partly due to also going from P255/70R15 with the 3.55 to LT245/70R16 with the 3.73 (means about half of the gear change was used up with tire growth). I'd like a 4.10 with my set-up (2000 RPM at 70 in OD; 2900 RPM in DD at 70).
Y2K™ Jim
Toreador Red, Keyless XLT SC SB 5.4L E4x4 4wDisc/ABS, 3.73LS, Skid, HD 7700# Towing, LT-245's on Chrome, Tube-Steps, Captain's, 6CD, Tonneau, named: "Nick"
Y2K™ Jim
Y2K -
Hey I have a 97 4.6L F150 2WD with 3.55 in the rear. I have 305/70/16's...for tires on her...what will or can I expect if I go to 4.10? I like Veloci do not want to loose my top end since in CA we run in the 70-90 depending on the freeways .i.e CA - Autoban 15 Freeway to vegas...lol
Oh yea my truck is an automatic for trany
1997 F150 4.6L, Flare side,American Racing Baja 16X8's, Goodyear Wrangler's LT305/70/16's ATS, Flowmaster 50 series, 3" cat,3.5 Suspension Lift kit, Tinted Windows, Superchip, Rancho 5000's
The OD/4th has adequate top end, 4.10s are not a problem for those speeds. If you focus on top speed w/ gas mileage considered, deterioration should be expected. Next, you will not feel the full effect of this ratio since you have a taller tire. I have had many cars with no OD and similar ratios, no problem on the highway, and the low end is great. Good luck !
