ford 8.8 ifs question
on
Just so you know a reverse cut gear still turns in the same direction. It is just the way the gears are cut. Any diff that will fit in the 8.8 will work on the front. You just have to pay attention to the fact that the front diff uses 28 spline axles. ARB makes an air locker for this diff.
on
The US site has one listed in their application chart. RD82 is the part number.
While the ARB is expensive it allows you to select when to lock it. It will work as an open diff till you lock it. To tell you the truth I forgot about the Eaton. It does the same thing as the ARB only it uses electricity to lock not compressed air. It could be argued that it is better because there are no air lines to leak and the ARB will need a compressor.
