05 3.55 swap with 04 3.73LS
Should be a direct bolt-in swap. Is the condition of the axle questionable...is that why you're asking about bearings, etc???
If so, and if you feel there's a need to go internal on the new axle, just keep your axle and upgrade the gears and all to 4.10's. 3.55 to 4.10 is a very subtle change, most would say not worth the effort. Swapping axle's makes it tolerable, especially if you're getting a good deal on the axle. But, if it's questionable and you need to go internal anyways, that benefit is now gone...IMO.
In this instance an 05 f150 4 x2 supercrew with 5.4 and 3.55 is 8,500, with a 3.73 9,500. Combined weight rating is 14,000 & 15,000 respectivly. Fifth wheel towing for the super cab is 8,300 and 9,300. Supercrew fifthwheel towing is not listed for this year as appropriate hitches were not available at that time. If we read the fine print it goes on to say weight ratings are decreased by 500# for trucks with 18" wheels. It's a bit tough to decipher when one considers all of the various and different combinations of vehicles.
I am open to corrections - thanks for helping.
Erik
Do you mean you want to change the entire diff with axle housing? If so, go for it and don't worry about bearings, etc. If you mean just changing the internals, I wouldn't bother just for that small change. This is a job for professionals. I'd go for a 4.10. With a 4.10 and overdrive the overall ratio is about 2.87 which isn't bad for the highway especially with today's large diameter wheel tire combination.
Another question: Have you already towed the 5th wheel with your Supercrew? I thought the Supercrew bed was too short for 5th wheel towing.
