2004 Grinding from Transfer Case
I have a 2004 F-150 and occasionally I will get a grinding noise from the transfer case I believe, when I am in 2wd. I first got it to go away when I would come to a stop then there would be a slight clunk and when I started driving again then it would be gone. Then when it came back I placed the switch into 4hi and it would go away then I could switch back to 2wd and all would be good. It does not grind all the time, just once in awhile it will start and I place it into 4 hi and it goes away. The 4X4 seems to work fine when I use it, and 2wd seems to work fine when it is not grinding. Anyone have any ideas? Thanks for any help you all can give me.
Troy
Troy
