9.75" Trac-Lok Rebuild Info Needed
Guys, I have some end-play in my axles, and assume it's due to the clutch packs loosening up (although the P.O. stated it was redone shortly before I bought it, about 10K ago.)
A few questions:
1) How different is the procedure on the 9.75 from that of the 8.8? (I did my Mustang without any problems.)
2) Does anyone have a link to a tutorial/detailed instructions?
3) Where is the best place to source the rebuild kit?
Thanks in advance.
Andy
A few questions:
Thanks in advance.
Andy
Get the friction plates, clutched from Randy's ring and pinion. Then you will need 2 new spring washers from ford. These washers go behind the actual clutch packs. These washers are what actually puts pressure on the spider gears. When I add gears before I put in a true trac, I rebuilt my trak loc, and add a extra .030" shim to each side to add a little pressure... You will need a extra hand to gut the spider gears out along with reassembly.
