Whirring noise coming from the driveline??
Truck: 2006 F150 FX4
Mileage: 110,000
2" autospring level, 18" wheels/33" tires
Symptoms:
I have a whirring/humming noise coming from the rear of the vehicle. I can hear it between the cab and the bed. And I don't think it is as far back as the differential. I don't hear it underneath the cab. It is speed dependent, not RPM dependent. I can hear it only when the truck is moving. I can hear it from 0 mph-top speed. It doesn't come and go with speed.
There is no clunking, grinding, ticking, popping, ratcheting, etc. It is a smooth hum. No vibration either. Truck drives fine, but the noise is fairly new and apparent.
I just changed my tranny fluid. There is no problem with the tranny and it is shifting and going into gear just fine.
I checked my u-joints and everything still looks nice and tight.
Not sure what it could be?
Transfer case? Output shaft? Maybe the bearing inside there?
Mileage: 110,000
Symptoms:
Tore the truck apart this weekend. Pulled the diff cover. Pulled the axles out. Replaced the axle bearings, changed the rear brakes (since the back end was apart anyway), changed the drive shaft u-joints front and back. Put is all back together and the noise is still there.
Pretty sure it is a pinion bearing in the front of the diff. Gonna take it to the rear end shop this week and get it looked at.
Once that is done the entire rear of the truck will have been rebuilt.
hummm.... had a similar issue but the dealer (2 different ones) said there was nothing wrong with the bearings in the dif. I changed the bearings and seals on the axel, new u-joints, rear brakes, shocks, bushings. Couldn't get rid of that noise. Only happend on turns, mostly right. I ended up adding "friction modifier" to the rear end and the problem went away, the Ford shop actually told me there was a TSB on it, 10$ only found it at the dealer.
Still thinking about replaceing the bearings in the diff anyway..... 900$, I may wait a while yet.
