Front end noise-Opinions?
My 2002 f150 4x4 5.4 has started making a grinding noise in the front end intermittently and when I turn or swerve to the left. It’s not a loud, as in gears or spines grinding, but a low growl more like wheel bearings grinding. It does not make the noise when braking or when going in a straight line, so I don’t think it is the brakes.
Thanks for your help!
Ron
Ron
That's the easiest and cheapest thing to start with. Look into that, and if that's not it then it could be a bearing in the front differential. Could also be something wrong the cv axle. But it happening while turning sounds more like a wheel bearing
