04 f150 4x4 acuators
Ok so i will probably get some of the acuall names wrong but here goes. Las t winter 4x4 quit working. Replaced vacume acuator on firewall worked for a short while. Now the acuators on the wheel engage when vacume is removed correct? So unpluged vacume lines at firewall still nothing. Well I wasn't sure how it worked so took it to two diffrent shops and got 2 diffrent problems. Spring came and didn't worry about it anymore. Now I had it on a drive on lift the other day and I couldn't turn the pass cv axle but could turn the DR side. So since no vacume since truck wasn't running the Dr side acuator is bad correct?
