Wicked noise coming from engine bay!
02, 4.6L
120K
AT
No performance issues with noise. All fluids topped and look good. Sounds like master cylinder area
Makes noise only at idle.
28 seconds in you will hear the noise.
http://www.youtube.com/watch?v=ALR_OolQHpc
Hope I can post links?!
Any ideas?
120K
AT
Any ideas?
BTW, I said in the vid about a brake booster, but I really dont know what im talking about lol...sounds like a pump drone..
One thing of note, Ive had the power steering rack replaced in the past and they said the pump was good then but maybe this is it? there are no squeels or whines like you hear when it dries out...no leaks either.
Did you have your defroster on? It sounded like i could here the air conditioner
compressor cycling off and on,which it will do if the defroster is on.
It sounded like i heard a click and the noise started , then another click and it stopped.
I agree with the pump noise. Sounded like something that was causing other things to shake at the same frequency.
If it doesn't happen are we talking compressor?
I started youtubing a bunch of bad IAC vids. I happened to come across one with an aftermarket intake and sure enough it was very similar.
Placed an order and got my part. 10 min swap, took it out for a rip, and nothing. Nice and quiet! FYI for yall who might be running an aftermarket intake.
