2005 f150 fuel pump problems
I have seen this a bunch of times, the usual culprit is the wiring harness under the driver's door next to the frame rail. If it catches a rock it damages the wiring inside the loom wrap. After a little moisture it corroded and loses the conductivity. Try that first, easy to repair if it is the problem. The wire is for the FPDM. Let me know.
