4x4hi light not illuminating - question on noise from TC
I recently picked up a 2005 fx4 4x4. The 4x4LO light comes on and when it engages you hear an audible mechanical switch of gearing. The 4x4HI light does not illuminate (only on startup it does), there is no audible noise of switching of gearing but the 4x4 does infact work.
I've done some searching but no one mentions any noises.
Its seems my steps are:
- scan the drivetrain dtcs (no lights on the dash but thats what some other posts say to do)
- replace IWE
Anything else I should think of doing?
- replace IWE
Tried to play around with it just now; lifted the car when the car is in 4wd-hi (in neutral and car on) the axles are locked, then put it into 2wd the front wheels are not locked to the transfer case but locked to the axles. In short the axles are always locked to hubs but the transfer case is what changes.
If your 4x4 is in fact working as it should, but the only problem is that you are not getting the light on the dash when you should, that's electrical, probably in the controller, and I'm not sure what to do there. Scanning for DTCs is probably the best place to start.
Also, your vacuum solenoid on the passenger side firewall should have a rain hood over it. If it doesn't replace it. You can get them for ~$20 on Amazon or eBay. Cheap insurance and easy to replace.
I picked up a vacuum hand pump from a friend and tested the system, the actuators are dead, the solenoid is also dead, and the vacuum lines are in good shape (sarcasm).... I spoke to a ford mechanic and he told me that there is no major issue with having the IWE system fail worst case it will temporary get stuck in 4wd. My actuator died in locked mode, I'm going to take them apart and see if I can unseize them (my guess is water got into the diapharm and messed it up). If not I will most likely leave them as is. When I connected the iwe to a vacuum pump the pressure did not drop, so no internal to external leaks. I'm surprised ford would use a pneumatic system, VW/Audi are famous for pneumatic systems (and the failure of them!!!).
The solenoids have always been plastic (but did have a metal backing mount for the earlier and a plastic hood for the current) and the IWEs always aluminum.
