CV boot replacement
CV boot replacement
97 F150. Need to replace outer drivers side CV boot. CV joints appear ok but not sure how old they are. I guess the steering knuckle has to be removed first. Must the entire axle shaft be removed to replace only the outer boot or is it easier to just replace the axle shaft with a complete unit, thus saving time splitting the CV joint from the race to remove the boot. Haynes/Chilton manual say outer CV joints are non serviceable so not sure if I can even replace the boot.
thanks
thanks
