rear end problem. please help
this is my 06 with a 5.4. its got the 9.75 axle with 3.73 gears. its got the single piece driveshaft. this whine your about to hear in the video started a couple months ago. since then i have replaced the wheel bearings and seals. and the diff fluid. and i did put in motorcrafts friction modifier. please watch the video and let me know if you know what the whine is.. oh and i know 100% its not the tires. and you can hear it over my exhaust even though in the video its hard too.and you cant hear the whine untill i get about 25 mph. thanks in advance for your greater knowledge
http://www.youtube.com/watch?v=YSk7z...ature=youtu.be
If I had the truck, I could narrow it down, but not from here lol. 2wd or 4wd ?
Jack it up, try to locate were it's originating from. If it 4wd, - remove the rear shaft, run it 4wd, - is the noise still present ?
I mean , can't you narrow it down better than that? Well, - post all the needed info anyway, all that you can anyway. So no one else wastes their time asking for details.
No mine didn't either and I checked 3 or 4 different times 'cause I was a little skeptical. After the gear install it was quiet again. Mechanic said the gears/bearing were starting to pit pretty bad along with my spiders. I told him to hang onto everything and show me and sure enough they were looking pretty rough. My $.02
Is the pinion seal leaking? When you replaced the axle bearings and seals were the axle seals leaking?
I had a pinion bearing go bad in a 74 Ford Stationwagon. I thought it was the tires at first. When I noticed that axle lube was on my right rear brakes and the pinion seal was leaking, that clued me in to what the problem was, a bad pinion bearing.
From the recording, I would guess it's the ring and pinion.
Or, it sounds somewhat like dragging brakes that don't have any pad left. You should have noticed that if you changed the axle bearings and seals though.
Noises are hard to diagnose in person sometimes, so good luck.
I listened again and I change my guess. I would guess pinion bearing or some other bearing in the diff.
