4X4-Shifting to 4L
Old 11-12-2000 | 11:16 AM
huffy's Avatar
Question 4X4-Shifting to 4L
I just bought a 1998 F-150 Lariat EXT CAB. Unfortunately, I do not have the owners manual and this is the first 4X4 I have ever owned. There is a manual shift located in the floor to switch between 2H,4H,N,4L. I can switch between 2H and 4H (indicated on the control display panel), but I am unable to switch to N and 4L. Is this a mechanical problem or operator error?
[This message has been edited by huffy (edited 11-12-2000).]
Old 11-12-2000 | 01:00 PM
huffy's Avatar
Smile
redlariet,
Thanks for the reply! It worked!
Old 11-13-2000 | 12:29 AM
redlariet's Avatar
Post
huffy,
good choice of trucks. The gear shift has to be in N to go to 4x4 low.
97 Lariet-sc-4.6-4x off road-auto-3.55 LS-
superchip-K&N-3"
pvc air box mod-Granetelli MAF
Old 11-20-2000 | 06:11 PM
LaserNAV's Avatar
Exclamation
Actually You need to be at a complete stop before manually shifting into 4L. The low gears are NOT synchronized like the 4H gears. You should however be able to pop it in and out of 4H while rolling down the road.
Do you have a manual gear shifter or Automatic?
2000 Navigator. Laser Red, Every option. , (4) cams-32 valve Intech (Jaguar design), Cross Induction Intake Manifold, SIX (6) Bolt Mains, K&N FIPK , Superchip, True Duel Flowmaster 50 series. 2X SISO , vented out each side. Rear air deflector, Bug deflector, PIAA, headlights (SUPERWHITE)
Looking at Hitting 400 Hp without a blower. Using in addition, headers (If possible)
(Waiting for JBA to develope Headers)
“91” F150 4X4 Shorty “Ultimate Off Road Edition” Borge Warner T18 4 speed, Traction Lock Front and Rear Differentials., Smitty Built Duel Tube Roll Bar, Moog Super Off Road Coil Springs, Factory 2” Lift Rancho RS 9000 Shocks , Stock Front “QUAD SETUP” 33x12.5 (B.F. Goodrich) Mud Terrain Warn Winch Combo Bush Bar with Warn XD9000I Winch. Full Factory Skid Plates. 302 Long Block, K&N FIPK JBA Chrome Headers, Custom Catback using Flowmaster Muffler, Duel out side behind rear wheel.
Old 11-24-2000 | 11:11 PM
powerstroke73's Avatar
Post
If it is the **** on the dash you can put it into 4L while still moving but it won't shift until in neutal and at a stop. It shouldn't hurt anything if this happens. All it will do is just sit there in 4H.
Old 11-25-2000 | 02:59 PM
summitman's Avatar
Post
To get it into 4WL you must be stoped with your foot on the brake and in neutal before you can shift between 4H and 4L.
Sorry to repeat what everyone else said but, I just wanted to make sure you understood.
98 f150 4.6 auto 4x4 supercab-short box/bright red & black/6 disk cd changer/ dynomax cat back/k&n fipk/super chip/lund taillight covers/clear corner lens/factory fog lamps/pace edwards box cover/ultra wheels/LT265-75-16 BFG/ westin nerf bars/steel horse billit grill & bumper insert/reflex shocks/bosch plat. plus 4/accel wires/auto start/left hand grab handle/skidoo summit 700 high mark/FORD DEALERSHIP
Old 11-25-2000 | 06:48 PM
Dennis's Avatar
Post
As I recall with the manual transfer case shifter, you don't have to be completely stopped or have your foot on the brake. Completely stopping makes the gears mesh easier though.
Main thing is to put tranny into neutral, then push the shifter from 2H to the left, then down thru N(eutral), then right to 4L. Try not to stop in N. Go smoothly thru N.
