Upgrading rear end?
Upgrading rear end?
Hey i have a 2001 2wd f150 that i just wrecked last week and tore the entire wheel assembly off and destroyed the rear end. Im going to have to replace the whole rear end and am wondering if theres any good heavy duty rear ends out there or if i can put a 250 rear end in it. Would the 250 rear end fit?
A relatively easy swap would be a 9.75 out of a 5.4 truck of the same year or close to it - just make sure it has the same type of rear brakes. I don't know if the driveshaft has to be modified. If the axle ratio is different, your speedo will be off - same thing if you put bigger tires on it. You should buy a programmer to reprogram it to compensate or it won't run quite right, the engine and transmission also use speed inputs.
