To Lock or not
To Lock or not
I just placed my order for a set of 4.56 gears for my truck. Now, there was one hill that really ticked me off this weekend because I had three wheels spinning and I need that fourth one to move. I was thinking about a Tru Trac, or a powertrax and have written both companies inquiries. My last option is the ARB but pricing them out, I see nothing less than 780 for the locker and compressor. Now for all of you out there, is the ARB worth the price if i'm taking her offroad almost every month, sometimes more than that. Next question is, what lockers are available for the rear? I have a limited slip but might want something more solid than that in the future. I know that the ARB is not compatible with the ABS excitor ring that sits in the diff housing since you have to replace that in the install. I'm thinking christmas present for myself. I've got the gears, next month may be the locker and then december might be install, we'll see. Thanks, klaibs
For the front or the back??
I would put a detroit locker in the back and an ARB in the front if you really want (need) to be locked up.
Ian
ps - I reread your post and figure you must be talking about the back diff since you mention the ABS ring. But if you only lock up the back you can still have three spinning since the front diff is open.
Ian
From Powertrax
The 9.75" model has been designed, but not put into production yet. No date
has been set for production either. Maybe summer 2002.
The 8.8" IFS model has also been designed and is waiting for approval before
being put into production. Maybe summer 2002 also.
This is for the No-slip traction system. In case you all wanted to know.
I just had the best idea. I wrote powertrax an email stating that I would be willing to be a guinea pig for these lockers. Let's see what they say!!!
Re: To Lock or not
klaibs,
hows it going? Nice, pic, I guess you're not bull****ting about offroading frequently. Anyway, why not get the Detroit EZ for the rear (exact same design, or near exact, as Powertrax, so much so there is a lawsuit, or was a lawsuit). I'm not sure, but I'd bet they make it for your application.
Then just wait for the Powertrax front application. That locked rear end should push you further than that ls, and you may be able to do without the front for awhile. That ARB is indeed serious stuff, but you know, I don't want drilling in my diff cover (then you are definitely changing out your axle fluid more often), or an air compressor mounted in my engine compartment , or a bigger alternator to feed all that crap. But I'm not doing stuff like you. Powertrax seems soooo simple. It's a question of how long can you wait?
ARBs rock! Basically go from an open diff for the street, snow and ice to a spool for offroading!
For the front, that is the best thing to install there with the front central axle disconnect system.
For the rear, I would leave that as it is working if both wheels are spinning. I assume the front only has one wheel spinning.
Forgot to add that with a ARB or spool up front, that is for straight only. YOu will not turn with it locked up, or at least what you are use to turning
As soon as the ARB unit is available for the 9.75 read diff I'm replacing my LS with one. I don't like LS in slick stuff. There are a dozen reasons the hard core off roades love those things. They rock! Besides, its good to have a compressor onboard for an easy tire air-up after playing in the dirt/gook.
Good luck -
Dumbest thing I ever heard while four wheeling - "Hold my beer and watch this".
Good luck -
From Tractech
Makers of Detroit lockers...I received this a couple days ago:
We have no plans at this time to change the design on the 8.8 Ford axle so
Randy's fix is the only way to go at this time. I am sorry but we do not
offer anything for the 9.75.
That was in response to a question I asked about putting the Trutrac up front and putting anything in the rear...
cpapdl, thanks for the compliment. I'm in the same boat with modifying that diff cover...I'm just soo torn right now...
I just received my 4.56's today so now I'm really looking hard for this locker since I want to do all the installations at once. I'm still waiting for word back from powertrax on being a guinea pig. Keep those finger's crossed boys/girls !!!
Re: looks like ARB
klaibs27
You need to learn how to market yourself better. Maybe if you had 4-wheeled through their production facilitiy, you would have won them over....or spent 3-5 years in prison..A real man would take the risk..
Anyway, what are you going to do for the rear? I'd worry about stressing that front axle (not trying to rain on your parade). I would think you'd want your bestessness in the rear with the stronger axle..Maybe TWO ARB's!!!!
ARB!ARB!ARB!ARB! Step up to the plate and go dual ARB'S They WORK! Or save some cash and go ARB front and spool rear. I've owned many l/s, lockers and spooled vehicles. ARB is the sweet set up on or off road. Spooled when you want, but doesn't attract attention in parking lots when you turn it off. If you want to go hardcore, don't even bother with the ARB air unit, add a York A/C compressor unter the hood and have onboard air. Will require some custom fab work but you'll have the SWEET set up.
