4.10 or 4.56?
4.10 or 4.56?
Right now I have 33" tires with the stock 3.55LS gears. I plan on getting 35" tires shortly, and maybe in the far future some 36". I want to get new gears so I don't have to deal with the power loss. Should I go with 4.10 or 4.56? Also, I do the occasional towing to the deer lease. Will 4.56 give me bad gas milage around town? Thanks in advance.
I suggest 4.56's. That's what I will be getting soon. If I decide to go a little taller I'll be still cover.
My Ride: 1998 F150 4x4 Lariat Supercab Flareside 5.4L in Oxford White/gold, ORP, Tow Package, 3.55 Gears.
Modifications:
K&N FIPK
Gibson Supertruck Exhaust System
Stepshield door sill protectors
Performance Accesories 3" Body Lift
Superlift 3" lift blocks
Performance Lift Lips
Gabriel Gas Ryder LT VST Shocks
Daystar Front Anti-sway Bar Polyurethane Bushings
Heckethorn Steering Stabilizer
35x12.5R16.5LT BFG All Terrain KO's
16.5x9.75 American Eagle 589's.
Photos at: http://www.communicomgroup.com/jmtruck
Modifications:
K&N FIPK
By my calculations (I think I'm doing this right) the 35s with the 4.10 is the same as the original 255s with a 3.63 gear and the 36s with a 4.56 is the same as the 255s with a 3.93 gear.
2000 XL 4.6 5spd 2WD reg-cab long-box 3.55 LS 235/70/16 Chestnut (not 2-tone) Raven-Cap
Best advice, take it from a pro. The best service, advice and prices for sure. This site will tell you everything you need to know if not, the people will. Just call their 800 number!
TD
http://www.ring-pinion.com/
TD
