No 4x4?
No 4x4?
I went to put the truck in 4hi and it wouldn't go in 4x4. I have the shift on the fly and I know it didn't go into 4x4 cause the light didn't show up. I tried again a few minutes later and it went into 4x4 fine.
Was the transfer case too cold or is something messed up on the truck?
<font face="Verdana, Arial" size="2">Originally posted by Ford Rules All:
I now figured out that the problem is only when the truck is moving. If I'm at a stop it will engage fine but when driving it won't work.
Is the shift on the fly feature broken?</font>
conway is right about 4Low you must be stopped and in Neutral.
Try engaging and dissagaging it a few times and see if it gets better. The shift on the fly uses a vacuum swith to engage the 4wd so maybee it was just stuck. It may work ok after a while.If not bring it to the dealer.
1999 F150 4x4 4.6V8 regcab/shortbed
Oxford White with Wedgewood Blue two tone, with Blue Captains chairs
Bullet Cat Back, Superchip, K&N FIPK Intake.
Centerline Saber rims 17x8" with Firestone GTA 275/60hr-17 tires.
Alpine CDA-7845, ADS P640 Amp, Focal Poly Kevlar seperates.
SILVER 2001 LIGHTNING on order
http://members.tripod.com/donf150/Welcome/id7.html
