Hey, guys, what's "axle wrap" mean?
Axle Wrap is when the springs don't hold the axle straight when you accelerate, allowing it to twist. I wouldn't worry about it, the rear springs on the F150 are fairly stong, and axle wrap should be very minimal.If the springs were very worn out you may experience severe wrap.
Hope that helps.
Hope that helps.
I will have to disagree, I think the springs are pretty weak, since Ford was trying for a smooth ride...I had to ad traction bars to my truck to try and stop it...still get it once in a while, depending on how hard I play. My truck is lifted but it happened before the lift too...as you can see in the photo we only have two full size spings and one little one...(4x2). DAVE
1998 F-150, SC/Flairside,oxford white 4x2,4.6,auto,3.55s,nerf bars,cls 111 towing,bed liner w/mat,Eagle polished wheels 16x10 w/Yokahama Geolandars 315/75/16s,all plastics guards/bug shields,air raid/k & n filter, superchipped, duals out the back corners, flow master 3 chamber, snug top lid, f-150 online sticker back window-honk if you see me!!! Fabtech 3 1/2 lift,3" spindles, 3" body lift=9 1/2 inches of lift, lift lips.coverking dash cover, Lumi Logo's (front and rear), clear front corner lenses, muth mirrors,dash mounted CB, (TX Chapter requirement,lol),personalized license plates, Superlift traction bars,Image tail light covers (painted).and it still fits in the garage, yeahhhhhh
San Antonio
DWESSELS89@AOL.COM
San Antonio
DWESSELS89@AOL.COM
If axle wrap leads to wheel hop (bed hop, truck hop, lookout it feels like the whole thing is going to shake to pieces!) then you don't need worn out spings. Mine has done it since day one. All you need to do is break traction. Mine will even start bouncing if I'm on it heavy in the rain at 30mph in second. I've never been able to do a propper burn out. The only thing that helped a little was 300 lbs of sand bags. Maybe it will get better when I get better tires.
2000 XL 4.6 5spd 2WD reg-cab long-box 3.55 LS 235/70/16 Chestnut (not 2-tone) Raven-Cap (and a '66 GTO with a '73 455, both combined cost less than a Lightning )
I have the 'lightduty' with stronger springs and still had the same problem. It was really bad in rain or dirt roads. After changing to Rancho's and Hellwig rear sway bar, it eliminated about 95% of it.
1999 F250 LD S/C XLT 4x4
5.4L, 3.73, 4R100 trans.
Flowmaster 40 "DF" series, K&N, Superchip, WMS Velocity Tube, Rancho RSX shocks, Hellwig rear swaybar, Stull billet grille, 2-PIAA Pro80XT's (120W), 2-KC Daylighters (150W), Clear Side Lens Mod w/ 9006 (55W bulbs). 265/70 R17 BFG AT KO's on 17x8 American Racing Atlas rims
Kenwood 7007 CD, Alpine 3342 Signal Processor, Alpine MRV-F353 5Ch. Amp, Pioneer TS-A6865 3-way speakers, MTX Thunderforms. CompuStar alarm/autostart. On the way: Performance Accessories 3" body lift, 33/12.5/17 ProComps, GSP grille guard and more KC's
