Best u-joints available
I am pretty sure that this is covered on here some where but with my lack of sleep and this 56k modem the search results are just way to slow.
I am thinking about replacing my u-joints but wanted to go with a good quality product. It seems that most you buy at the local parts places just do not last. Right now I have about 130K on the factory ones and feel that it is about time to change them out. They are not in terrible shape but I can feel a clunk when I go into drive or reverse and I do hear a slight nosie and vibaration when I let off the gas. I do not want some 100 a joint u-joints but I do want a good quality joint. Preferrably the sealed type as IMO they are stronger and all the sealed types I have fooled with out lasted the greasable type 2 to 1. Thanks
Insist on Spicer, greasable type u-joints. Undoutably, the BEST.
CAUTION: If replacing u-joints in an aluminum driveshaft, Spicer makes a "special" U-joint that has a distinctive coating that prevents corosion from aluminum to steel components.
The u-joint for aluminum driveshaft is the same as u-joint for steel; except, coating versus non-coating.
on
Napa heavy duty u-joints. I believe they're made by Spicer. Lifetime warranty. The cross is not drilled for a grease zerk. They grease thru one of the bearing caps. They require a special grease fitting on the grease gun- looks like a fat needle.
Since they don't have the grease zerk hole they are stronger and you don't have to be install them for the correct rotation. Standard drilled joints should be installed so the rotation of the transmission tail shaft pinion turns toward the hole and then the rear drive shaft pinion turns toward the hole NOT away from it. This compresses the hole which is stronger than trying to spread it.
And they're reasonable to boot.
