Puzzled.
![Lightbulb](https://www.f150online.com/forums/images/icons/icon3.gif)
Your sig. doesn't give any information that is relevant to tell this. Most F-150s have an "open" rear differential; the LS is an option which most trucks on the lots do not have. If you can't tell by driving, you can look at the axle code on your driver's side door jamb and decipher the code with a search here or post it. The first character in the 2)character code is usually a "1" for open or a "H" for a LS. There is also a metal tag on one of the rear end cover bolts that has the actual gear ratio.
Originally posted by WOLVERINE
I guess it does'nt have it. What is an "open" rear differential?
on
WOLVERINE,
You have an open DIfferential. What it means is there is no clutch pack in the differential. What the clutch pack does is hold both axles together most of the time. When you go around a corner, the outer wheel wants to turn at a greater speed than the inner one. When the grond is dry the wheels will not slip because of the traction afforded by the dry surface, this will cause the clutches to slip and allow the wheels to turn at different speeds. When you are on a slipery surface there is often not enough traction for the wheels to cause the clutches to slip so both wheels turn at the same speed causing the truck rear end to slide sideways.
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
LS is the way to go!
I agree with JMC in that the limited slip rear end is preferable in most cases as it does improve traction greatly. I have only ever owned rear drive vehicles and all but 1 had the LS and wow what a difference! My last 2 vechicles have been F-150's and were equiped with the LS. My 99 was a 4.2l xl supercab 2x4 and I never got stuck (onroad) even with our Canadian winters. My present truck is an 01 with the 4x4 orp xlt supercab flareside 5.4l I can't wait to test this thing in the snow! I figure with all 4 wheels locked I will be practically unstopable
The only instance I can think of where the LS could get you in trouble is on a slippery road that has a large crown to it then it might cause your truck to slide towards the ditch at the wrong time. But in my opinion it is an OPTION that is a must have.
![Big Grin](https://www.f150online.com/forums/images/smilies/biggrin.gif)
