How to install a speedo gear?
I bought the 21 tooth speedo gear I need to fix my speedometer. I had to drive an hour to get it and when I got it I looked at it and said "This is it??" Its a tiny purple piece that was $6. It was almost not worth the drive up there. ANyways, now I have it and I have no clue what to do with it. Does anyone know of any instructions on the net, or have any directions on how to install this little bad-boy?
1997 Ford F-150
4.2 L V-6
Thrush Turbo Tube catback exhaust
K&N Air Filter
Window Tint
Pioneer 7000R CD player
2 Rockford Fosgate DVC HX2 10's
Rockford Fosgate 500a Amp
Lund bug shield
Vent Shade Vent Visors
GTS headlight blackouts
Bedliner
Chrome Toolbox
3" Body Lift
305/70R16 ProComp Muds
16x10 Eagle 589
Chrome Westin Nerf Bars
4.10 Precision Gears
Custom Key racing stripes down both sides thanx to some a**hole in the HS Parking lot.
My WebPage
1997 Ford F-150
4.2 L V-6
K&N Air Filter
Window Tint
Lund bug shield
Bedliner
Chrome Toolbox
3" Body Lift
16x10 Eagle 589
My WebPage
It takes about 5 minutes to change on my truck. The vehicle speed sensor (VSS) is located on the drivers side of the trans near the tailshaft. It has two wires going into in and is held in with a pawl style clamp like a ignition distributor. Remove the clamp and pull the VSS out. There is a small clip that holds the gear onto the sensor. Pull the clip, remove the gear, replace the gear and clip and reinstall. Little or no trans fluid should leak out while you do this.
97 XLT S/C Long Bed 2wd, 4.6 Romeo, 4R70W trans, 201,000 miles
