4x4 Front Axle Code/weight rating
I am trying to find the front axle weight rating for my '93 F150 4x4. It is missing the sticker on the door post, but it has a sticker on the front axle with the following:
D-105 J
Dana P/N: 6104143
Cust P/N: F3TA 3002 AMA
3.54 STD
CBA N S 44
any ideas?
thanks,
Chris
D-105 J
Dana P/N: 6104143
3.54 STD
CBA N S 44
any ideas?
thanks,
Chris
All's I can tell you is that the very last block on that door sticker should say "spring" and that section should have 4 blocks under it. The second from the left one pertains to the front axle. The first and third block is for auxilary / optional usage. The last block is for the rear springs. The ones listed as used in non 4X4 vehicles in block 2 (front springs) are J, K , L M, N, P, R & S. For 4X4's they are 1, 2, 3, 4, 5 & 6. These are then reference to a code. Example J = F65A-5310-JA and so on. I do not know what that code means from there but a dealer should be able to take that and tell you. This is from a refernce in a 97 factory ford manual so I do not know if it applies in 93 but it might. Hope it helps.
