Engine RPM with gear change
Changing gears in my SCREW from 3:55 to 4:10.
Currently I have 31.5" tires which are 1.5" taller than the originals. With these tires my engine is turning 2000 rpm at 75mph. Anyone know what my engine rpm will be at 75 mph and the new 4:10's?
Is ther an online calculator for this?
There are many quality manufactuer's of differential ring & pinions. I have had good luck with OEM Ford and U.S. Gear.
Some of the other brands include: Precision Gear, Motive Gear, Auburn Gear and others (whick I cannot think of).
If you do not have the experience or Technicial expertise to do the gear change, I would highly reccomend using a professional to do the job.
Countless times I have seen un-experienced people attempt a rebuild or diff. gear change--wasting alot of $$$.
Good Luck, Gearman
Good Luck, Gearman
