Tranny Clunk?
Tranny Clunk?
I just purchased a '97 F150 XLT-5.4L-O.R.P. 4x4.
Whenever I come to a stop or leave from a stop I get a clunk sound from the rear.I've read here about a few solutions(heavier springs,tailshaft lube),and my question is how do you lube the tailshaft?Is this the shaft that enters the rear end with the rubber seal on it?Any help would be appreciated!
I have a clunk when i put my truck in drive or reverse, also when i am doing a rolling stop and go it happens bad. THe clunck that is.. This clunk you are hearing are the universal joints. I have changed mine about 3 times and everytime i change them the clunk goes away. BUt my problem is that i am too cheap to pay someone to change the joints so i do it myself. But it never fails everytime i do it i knock the bearings out of line and ruin the u-joints as i reinstall them. I plan on changing them again but not by myself. The easiest thing to do is remove your drive shaft yourself and bring it to a shop for them to change. And buy your u-joint ahead of time from autozone, they go for about 13 dollars and are also greaseable joints.
Hope this helps...
Hope this helps...
Well I sure didn't expect the childish responses to my problem,thought this was a forum for helping each other out.In any case,for those of you who have this problem with your truck, I had my truck in for service and it was the slip yoke.I had it greased and the clunk sound has gone away.I don't think I'll look to this forum for any help in the future.Thanks for nothing.
Jeez, Jhonnyhawk, don't go away mad. I just thought Max's abbreviated response was funny.
Anyhow, you will be turning your back on a wealth of great info about your truck if you leave.
Periodically, though, you will find that even though someone may not have the answer you are looking for, they may make an informal comment in the name of levity. If nothing else, it keeps your thread alive which may eventually generate the response you are looking for.
Glad you got your truck fixed though...
Hmmmmm????
I'm always suspicious of someone THAT sensitive about issues of "rear-end shaft lube". Keep up the funny, it's rare enough these days!!
Oh, by the way...it seems I'm having a problem keeping my rad hose inflated..when I turn the truck on the hose gets stiff and hot, but then starts to leak and gets limp...any suggestions??
Chill, jhonnyhawk. Next time you're waiting for a serious response, do a search of the site.....your particular topic has come up a few times before. Give it a try.....you'll like it. BTW, don't be suprised if you need to have the slip yolk greased occasionally (i.e., the thump may come back after a while).
ernie
ernie
