4x4 or 4x3?
still 4x3
In soft sand, all four wheels will dig until one of the front wheels is held up by some thing such as solid ground. If you have one tire on solid ground and the other on say ice, the one on the ice is going to be the only one that spins. Try it out. You'll see what I mean. Of course, I'm assuming that you have a 97 or newer truck. If you do, you definetely have an open front. Even if you have the LS, it's still only a 4x2 if you get as articulated as this...
the factory limited slip can't turn the stuffed wheel on the other side so you're back to a 4x2.....
