Need serious help with drivetrain prob...
Ok, i haven't offroaded in a while and thats why this is so freaky...my 97 F150 4x4 is driving sideways. The rear axle seems to be an inch or two farther to the right than my front suspension. The truck seems to veer to the left if the wheel is straight. I thought it might be just a simple steering wheel adjust, but no avail. It happened all in one day and i'm not sure how...a good tire,brakes,suspension shop in town said my rear may have gotten "tweaked"!? I made a little website thingy with pics to help explain...for those of you who know much about rear suspensions, or could give any advice, please go to:
http://www.geocities.com/rsschoir/mytruckprob.html
Thanks guys, i really need help on this one...
-brandon
-Brandon Warford
97 F150 4x4 Sport Brt. Red SuperCab
4.6l Triton V8
3.55LS
3" Performance Acc. Body Lift & lift lips
1-1.5" torsion bar adjust. so it sits level
Clear Corner Lenses
315/75R16 Yoko. Geolander MTs
American Racing Atlas 16x10
Pioneer 8000 3D series
Boston Acoustic 5x7s
Sony Xplode 4ch Amp
(2) 8" RF XLC Subs
True Dual Exhaust
--(2) Stage 3 Flows (Exits like the Lightning)
Custom 4x4 Sticker
Viper Alarm
FUTURE MODS:
4.56 gears
Repaint around Headlights where clearcoat is coming off >=(
Possibly a Manik Brush Guard and Roll Bar--we'll see
Thats about it for now!
Killintime4fun@aol.com
"THROUGH the river and OVER the woods to grandmother's house we go."
"...the road curves to the right and there are a lot of signs that say you cannot turn left...TURN LEFT."
-brandon
-Brandon Warford
4.6l Triton V8
3.55LS
Clear Corner Lenses
Sony Xplode 4ch Amp
(2) 8" RF XLC Subs
True Dual Exhaust
Custom 4x4 Sticker
Viper Alarm
FUTURE MODS:
4.56 gears
Try parking with the wheels fairly straight. Then measure from the front edge of the front tire to the front edge of the rear tire on both sides. If they differ an inch or so, you may have sheared a spring bolt & the rear axle has shifted.
97 Lariet-sc-4.6-4x off road-auto-3.55 LS-
superchip-K&N-3"
pvc air box mod-Granetelli MAF
superchip-K&N-3"
Very nice sketches, BBRLFM!
When you do redlariet's test, you probably will find that one rear wheel is either too far forward, or too far back. This is tilting the axle, so the front wheels have to tilt too to get it to go straight (but looking crooked down the road). If you look at the top of the rear axle, right where the spring connects, there is a steel bracket that lines up the spring leaves with the roundness of the axle housing. There is a pin that runs down through the spring to this bracket. If that is sheared, then only the U-bolts clamping force would be holding the axle in the right place on the spring leaves, and the axle will move some. I'd be surprised if its anything other than what redlariet diagnosed. Let us know what you find.
on
BigBad.....,
There is a recall on the rear single axle 1997 F150 springs. Check out http://www.nhtsa.dot.gov/cars/proble...ls/recmmy5.cfm BTW any allignment shop worth its salt will be able to diagnoss the problem.
Regards
Jean Marc Chartier
00 F-150 XLT SC Flairside 4x4 4.6 w/5spd 3.55LSD
Warn XD9000i, skid plates, Draw tite class III,
Rancho RSX Reflex shocks, MAC 8.8 Axle Girdle
BFG 285/75 R16 MTs,
Borla Cat Back, Headman Headers,
Custom air intake system with modified
air box, Ported Throttle body,
Shortened MAF sensor tower,
K&N air filter,
Superchips
Regards
Jean Marc Chartier
BFG 285/75 R16 MTs,
K&N air filter,
Superchips
