Transfer case fluid
Transfer case fluid
I have my trans and transfer case out due to my transfercase going bad on me and I figured I would put a clutch and slave cylinder in since I was over half way into it already. My question is can I use synthetic fluid on either or both and what would any of you recomend.
1997 f150 4x4
extended cab, xlt
4.6, 5 speed 3.55 gears
1997 f150 4x4
extended cab, xlt
You can use synthetic for both. I would recommend Amsoil if any........
2000 Ford F-150 Lariat Ext. Cab, Short Bed w/ Off Road Package & 5.4 Triton V-8, Husky Floor Liners, Putco Side Rails, Kenwood eXcelon KDC-X815 CD Receiver, 4-Pioneer 6x8's, Kenwood 6 Disc CD Changer
http://www.amsoil.com/products/tgo.htm
Got if you need some.
http://www.amsoil.com/products/tgr.html
Got in Series 2000 SAE 75w140 or 75w90.
AMSOIL Series 2000 Synthetic 75W-90 Gear Lube delivers unbeatable protection and fuel economy. It has the film strength required to deliver all the protection heavy-duty and high-stress applications need in a fuel-saving viscosity grade. Recommended for use in all passenger vehicles, commercial trucks and race vehicles.
AMSOIL Series 2000 Synthetic Gear Lube offers an exceptionally low coefficient of friction for superior power transfer, heat control and fuel economy.
In fact, independent testing shows class 8 vehicles with AMSOIL Series 2000 Synthetic 75W-90 Gear Lube in the differentials obtained up to 4.83 percent more mpg than vehicles equipped with another popular gear lube.
AMSOIL Series 2000 Synthetic Gear Lube lasts longer than conventional petroleum gear lubes do. In non-commercial passenger vehicles operated under normal conditions, AMSOIL Series 2000 Synthetic Gear Lube does not have to be drained. In cases of severe water or dirt contamination, a chemical lube analysis can determine if the gear lube is still serviceable.
Good Luck and let my know if I can help.
Ruger's F-150
"With Amsoil You Can't Go Wrong"
E-MAIL ME:
pureamsoil@bigfoot.com
MY HOME PAGE:
PureAmsoil
Ruger's F-150
E-MAIL ME:
MY HOME PAGE:
PureAmsoil
on
gtrjim,
The hole in the plug is a 3/8 inch square.
In a pinch you can use a 3/8 inch ratchet but you may have to hold it in place. There is no allowance in the plug for the little ball in the ratchet head. A 6 inch extention will make it easier to reach the plug. Check out http://www.arizonatools.com/catalog/...es/Accessories
they show the special tool.
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
