Need help idetifying rear end
Here's where I got my gears. The chart shows what's available for Fords. My tag said 975 on it after the 331 gear ratio, but maybe that 10 2 on yours is the 10.25?
http://www.ring-pinion.com/a-ford.html
Your diff. is a 10.25" corporate, Sterling axle. It can be re-ratioed to 3.73 or 4.10. Can't remember if 10.25" offers a 4.56 ratio.
Your diff. appears to have been manufactured on 1/16/89.
When purchasing parts (such as ring & pinion), You have the earlier style, or shorter pinion. Pinion in 1992 & later is longer & requires taller (different) yoke.
You may want to purchase a diff. master overhaul kit when changing ratio. master kit would include all bearing for R/P & diff. side brg's., new pinion nut, pinion seal & crush sleeve. Master kit should also include a pinion shim kit & diff. side brg. kit.
good luck, gearman
Your present diff. was built with 3.55 ratio.
good luck, gearman
