Single clunk in reverse
When i put the truck in reverse and start driving the i hear a single clunk after driving 8 feet and then nothing else. It sounds like it is coming from the rear axle but i don't know if it's the diff or not. Any ideas? Hopefully it's just the gears in the rearend, i have the new parts all ready to go in anyways
-Jon
-Jon
If you have a 4x4, when was the last time you changed your transfer case fluid?
that long hunh?
Change it and use a good MERCON V fluid. I believe in Amsoil in the transfer case (only need two quarts). Royal Purple may be another good one.
If you have a 2x4, then I would suggest putting the rear end on jack stands, put the tranny in neutral and give the rear u-joint a shake. Look for excessive play in the pinion (rear-end side of the rear u-joint).
that long hunh?
-Jon
-Jon
I believe that the recommended change interval for the transfer case fluid is 30,000 miles.
Changing is easy! there is a plug on the bottom (3/8 ratchet to remove) and one on the back (just like the rear end).
Pull the plug and catch the fluid. then, put the bottom plug in and fill through the back plug until fluid reaches the fill hole. Install the rear plug and you are done.
Be sure to verify what fluid is required in your vehicle. my 2000 and 2002 both required MERCON V. I used Amsoil (personal preference).
