???? Non limited slip ????
I have a 97 F150 2x4 and not more than 2 weeks ago I did a burnout... now I'm not tryin to brag or anything but this is where my problem comes in. I did the burnout with both tires (Limited slip right?) but I was just reading an article on here that gave the rear axle codes and my axle code in my door say's it's 18... and the code that I got off of here say's that it's 3.08 gears with no limited slip... is this possible?
- Curious
- Curious
on
Qub3d,
It is possible under certain conditions that both wheels will spin without a limited slip differential. I used to own a 1972 Datsun 1200 that would lay down 11 yards of rubber from both wheels with an open diff. Raise both rear wheels and spin one of them. If the other wheel turns in the same direction you have a limited slip. If it turns in the opposite direction you have an open differential.
Regards
Jean Marc Chartier
SEE us play;
http://www.F150world.com/michapter/
00 F-150 XLT SC Flairside 4x4 4.6 w/5spd 3.55LSD
Warn XD9000i, skid plates, Draw tite class III,
Rancho RSX Reflex shocks, MAC 8.8 Axle Girdle
BFG 285/75 R16 MTs,
Borla Cat Back, Hedman Headers,
Custom air intake system with modified
air box, Ported Throttle body,
Shortened MAF sensor tower,
K&N air filter,
Superchips
Regards
Jean Marc Chartier
SEE us play;
BFG 285/75 R16 MTs,
K&N air filter,
Superchips
"It is possible under certain conditions that both wheels will spin without a limited slip differential." I've done several actually and all times both tire's have spun... I used to have an 85 Olds cutlass and I used to do a burnout with only tire... that wasn't limited slip =\ Could the codes be wrong?
'97 F-150 2X4 XLT Compustar alarm\remote starter K&N Air filter with Rain away on the window's =)
<font face="Verdana, Arial" size="2">Originally posted by JMC:
</font>
</font>
1989 F-150 XLT Lariat: 2WD 302 5spd[*]Performance Accessories 3" Body Lift[*]33x12.50.15 BFG A/T's on 15x10 AR Rims[*]Rancho Steering Stabilizer[*]Rancho RS 5000 Shocks[*]K&N Air Filter[*]Gutted Cats with Straight Pipes For Now...
Go Full Speed or Go Home!
Just look on the outside of the rearend for the tag and the 1st numbers will tell you what gears are in it...........lol...
1997 F-150 XLT 4.6 REGULAR CAB, FLARESIDE PACIFIC CLEARCOAT GREEN 5-SPEED. WESTIN NERF BARS, POWER EVERYTHING,BUG SHIELD, EX-TANG SOFT COVER, BED LINER(FORD).
Better 1/2 : 92 Red T-Bird.
