rear end shudder
Old 06-18-2001 | 07:52 AM
SkipF-150MICHIGAN's Avatar
Post rear end shudder
just had my 2000 f-150 ext. cab in for service on a shudder/vibration, 26,355 mileage. turns out they replaced my rear clutch packs. took it home and the noise and vibration are worse. they told me to drive it another 300-500 miles before it will go away. said it was normal? when i put it in 4x4 and try to turn aarear axle locks up and skids? any ideas? any help would be appreciated
Old 06-19-2001 | 10:49 AM
maximas's Avatar
Post
My truck (2000 f-150 4x4)is doing the same thing after 12k miles. The first time I took it back, they said they made an "adjustment" and added some additive. It was fine until the next day and the grinding got worse. The truck is currently at the dealer now. I'll let you know when I get it back what they did.
Old 06-24-2001 | 02:13 PM
maximas's Avatar
Thumbs down
Well, I got a call from the service rep. and he said that they found the problem. He said that he found a bolt stuck in my right rear tire and this was causing the shudder/grinding noise I was hearing when I turned. I could not believe he was serious. I told him there was no way a bolt was causing the whole truck to vibrate and shake while turning. He said he had two people drive the truck and they couldn't hear or feel anything. Anyway, I went to pick it up and the very first turn I made, it sounded like the wheels were going to fall off! I turned right around and made the mechanic ride with me so he could hear the noise and after he did, he immediately told me something was wrong and I took it back for the third time. This is ridiculous, I'm so frustrated with this crap.
