I accidentally switched to 4hi at 60mph
Old 08-22-2002 | 06:04 PM
chonky150's Avatar
Question I accidentally switched to 4hi at 60mph
I was going down a country road in Florida and not paying too much attention, I accidentally switched from 2hi to 4hi thinking it was the air conditioning. Do you think this would be detrimental to the 4 wheel drive system? let me know what you think. I haven't put it in 4wd since just to be on the safe side.
Chhorn
chhorno@hotmail.com
Old 08-22-2002 | 06:07 PM
XLT-Sport's Avatar
I don't know anything about 4x4 but ...Welcome to the site!!
crashthings's Avatar
Did you hear any loud noises when you did it?!!!
I wouldn't worry about it. I have shifted at over 50 before. Especailly if you were traveling straight! The front was traveling the same as the rear. I really don't see a problem with it.
Old 08-22-2002 | 07:39 PM
mthunwardsen's Avatar
If you didn't hear anything bad, then you should be okay. I think I have done it before too, I think it just doesn't shift until you slow down. Just wait until you hear the clunk when you shift into 4 Low, you swear it was your transfer case hitting the ground. Good luck.
Old 08-22-2002 | 08:53 PM
cpadpl's Avatar
Re: I accidentally switched to 4hi at 60mph
chonky150
I have a manual 4x4 shifter, so I'd have to be really drunk to accidentally shift it into 4-Hi, but I believe - and the others here will correct me if I'm wrong - that no damage can result in your situation because the magnetic clutch will NOT engage at a speed higher than 55, so no damage possible.
This seems like an issue Ford would contemplate, i.e. a **** just like the A/C, and would make provisions for.
Old 08-22-2002 | 10:06 PM
Y2K 7700 4x4's Avatar
It probably made the shift without any problem.
If you had twisted it to 4 low, there's an interlock mechanism that prevents it from shifting into low if you're not in neutral -- so crank away (we've all done it -- reaching for the fan control).
Old 08-23-2002 | 05:30 AM
svtoby150's Avatar
No Problem....
It's a Ford, It'll be fine.........If it didn't break then prolly aint broke.
Welcome to the site
Old 08-26-2002 | 04:44 PM
mxracer514's Avatar
cpadpl, you are correct the gem module will not allow a shift at 60 mph.
Quick Reply: I accidentally switched to 4hi at 60mph
