Buried
Old 01-28-2008, 11:00 PM
Ford4x4er's Avatar
what tires u running?
Old 01-31-2008, 04:02 PM
iluv_mud's Avatar
The tires i have are 285/75/16 green diamond mts the rear end finally broke last week pulled the diff cover the spider gears on the left side are gone ring and pinion is fine but i just ordered a detroit locker through work cheap so i should have the truck running next week
Old 02-01-2008, 02:22 PM
2005lariatky's Avatar
Is that truck 4wd?
Old 02-04-2008, 11:38 PM
Folmar150's Avatar
Why in the hell would you push him out? You would have royally f-ed up your bumper
Old 02-05-2008, 02:46 PM
Mr. eXtreme's Avatar
OPPS..... Did that with my last truck!!
Originally Posted by Toyz
wow, your back tire is tucked, that passenger side rear must be buried good
Been there done that!! Be sure you change that diff fluid!
Thought mine would be ok... YEAH NO!
Blew the ring gear threw the diff cover and locked up the axle on the Highway.
Best part is that after hours and hours of cleaning the week before.
I was able to get everything I @%&* up coverd under warranty!!
Old 02-13-2008, 11:36 PM
iluv_mud's Avatar
Yea my truck is 4wd and about the bumper the truck is only used to go wheeling since i got my other truck running (1991 f150 with 331 stroker) and if u saw the truck in person the bumper would is the least of my worries. Ive previously pushed someone through a mud pit so figured i would gaive it a try. I cleaned th hell out of my truck before i had it towed to the shop who rebuilt it before 10000 miles ago and they wouldnt warranty it the ring and pinion is fine but the spider gears on the left side of the diff are completly gone so i said f**k it and i just ordered a detroit locker and 4.56 gears since i also just purchased an rcd lift
Old 02-13-2008, 11:42 PM
Shinesintx's Avatar
I am an idiot...I thought the rear axle was broke...Your visual reply helped me figure it out, and I learned a new word. (tucked)
Quick Reply: Buried
