Full wiring Diagram?
Old 02-26-2008, 01:04 AM
06150xlt's Avatar
I found a site that has all you need (alldatadiy.com) its 24.95 a year for all kind of stuff like wiring diagrams for the entire truck and also recall info...and more. You gotta check it out. If you google the site name plus discount code you can get it for 12.95 a year..I did. Only downfall to the site is that you can only be subscribed to one vehicle of it cost 14.95 a year more. But if you want a certain diagram...let me know and I'll try to look it up for you and send it to ya. But only for a 2006 F150 w/5.4L.
Old 02-26-2008, 07:36 AM
colport833's Avatar
wiring
sure thanks....where do the wires for the Cargo light run? I `ve heard the drivers door sill..up the b or c post across the roof....am I close?
Old 02-26-2008, 10:03 AM
projectSHO89's Avatar
Quite a few of us have the factory service DVDs and can look up and post individual diagrams as requested. Just keep your request focused.
Original DVDs (not bootlegs) have been selling recently on ebay for as little as $10 per disk.
Steve
Old 02-26-2008, 06:44 PM
markielee1's Avatar
06150XLT,
hello,
read your posting concerning wiring diagrams. I have a 2004 F150XLT and want to tap into the main ACC from the key switch. Do you happen to know what color code the wire is? Installing some headrest monitors and I believe that's the safest place to tap into power....
Thanks,
Mark
Old 02-26-2008, 08:33 PM
06150xlt's Avatar
colport883: I doesnot show the actual routing of the wire it just gives to the wiring diagram.
markielee1: Aways hot Light Green-Violet
Hot in either Start or run Dark Blue -Light Green
ACC Black-Light Green
or if you want send me you email address (yotasprt88@yahoo.com) and I'll email you the diagram
Old 03-26-2008, 03:57 PM
lotusteve's Avatar
Question 2006 PCM pin out needed
Steve
As a new member I can't contact you could you please send me pin out diagram 2006 F150 PCM
Old 03-28-2008, 02:01 PM
The pinout can vary depending on the engineand transmission, information that you have not provided.
Steve
Old 03-29-2008, 12:44 AM
je3169's Avatar
What discount code did you use.
John
Old 04-01-2008, 02:25 PM
06150xlt's Avatar
Auto - USD $12.95 For One Years Access To ALLDATAdiy.com
Reg. USD $24.95.
After choosing your vehicle, enter the following Discount Code in the Program Code Field: 8001292
Offer expires 7/1/07.
Old 04-01-2008, 04:18 PM
je3169's Avatar
Thumbs up
06150xlt thanks
Old 02-16-2018, 10:49 AM
jvs06fx4's Avatar
2006 Ford F150 FX4 5.4l 4R70W transmission
Can anybody send me the wire diagram and pinout for this truck. I'm trying to track down a broken wire,bad solenoid or bad pcu. Thank you.
Old 02-16-2018, 08:12 PM
I think the OP's subscription ran out like 10 years ago...
Old 03-02-2018, 01:58 PM
F150SuperCab2's Avatar
Where do I find wiring diagrams and fuse locations for my 2003 f150?
Old 03-02-2018, 02:15 PM
My turn signals and brake lights do not work on my trailer, only running lights. Is this a simple fix?
Old 03-02-2018, 02:28 PM
Fuse locations are in the owner's manual. If you don't have one you can download one.
http://www.fordservicecontent.com/Fo.../03f12og5e.pdf
Quick Reply: Full wiring Diagram?
