shift linkage problem E40d
Old 05-07-2014, 11:07 PM
Taylorls2009's Avatar
93 f150 5.0 AOD auto trans
Shifter on the coloum doesnt go into park, says park but its in reverse..... says R but in nutral says N but in drive so on and so forth.
Can my ljnkage be loose, I can shift it manually by hand under the truck fine but on the coloum it wont go into its proper gear. What can I look for under the dash?
Old 05-10-2014, 08:32 PM
USAF93's Avatar
there are two brass looking bolts that came loose up under the dash. Lay on your back looking up above the brake. Here is a pic.
Old 05-10-2014, 10:56 PM
No pic there, try again.
Old 05-11-2014, 07:35 AM
USAF93's Avatar
It shows for me. Hmmmm. Not sure how else to get it posted. The pic is at http://www.ford-trucks.com/forums/at...6&d=1309224807
Old 10-11-2019, 05:40 PM
Offshore's Avatar
I have the same problem with my 98 4.2 f150. I checked the shift bracket and it is secured properly. Any ideas?
Old 10-11-2019, 06:46 PM
Not exactly applicable to your truck - this is for pre-97 with AOD/E4OD. You have a 98 with 4R70W.
Quick Reply: shift linkage problem E40d
