Truck starts, runs, dies every minute
2004 F150 200,000 miles. Runs and drives great. I parked the truck for about 1 month. When I tried to start it, the battery was dead. Charged battery and started the truck and it idles fine, BUT every 60 to 90 seconds it shuts off. Will immediately recrank and run fine, and then die after 60 to 90 seconds. No codes. I can keep the RPMs up and keep it from shutting off, but it still tries to die every 60 to 90 seconds without exception. Anyone have this issue before?
Clean the throttle body.
https://youtu.be/JPNnHU6PYbo
Also check the FPDM for corrosion on the back side. Change the fuel filter and put some Techron in the gas.
