Failed emissions today because this was not mounted?
Old Yesterday | 05:33 PM
Knucklz's Avatar
Any help would be greatly appreciated Not sure what I need to mount this wiring harness properly, Thank you!!
Old Today | 11:43 AM
MKTRUCK's Avatar
There is a bracket that OBD2 connector plugs into. Did someone install a device(Tee off of the OBD2)? If so the bracket and OBD2 connector with bracket may be there.
Bracket example:
Amazon.com: MITOB OBD2 J1962 Female to Open Pigtail Cable Bracket OBDii Port Replacement Cable 1ft/30cm : Automotive Amazon.com: MITOB OBD2 J1962 Female to Open Pigtail Cable Bracket OBDii Port Replacement Cable 1ft/30cm : Automotive
Ford Pigtails: Wiring Pigtail Kits Identification Guide | Motorcraft
Check out sheet 36 and 37(has your plug in your photo).
Good luck
Quick Reply: Failed emissions today because this was not mounted?
