99 XL door panel removal
Old 05-04-2003 | 06:36 PM
carson's Avatar
I have searched the forums for info on removing the door panel and havent found step by step instuctions on removing the door panel with no power locks or power windows. Im too chicken to start trying to pop off the trim without some concrete data.
Can anyone confirm how to do this for my particular setup? I do not see any screws or bolts or clips. I want to replace my factory speakers up front. I have a 1999 f150 xl.
Thanks in advance.
Old 05-05-2003 | 06:49 AM
2Trucks1Wife's Avatar
Take off the bannana shaped trim piece on the top of the door (use screw driver to find the clips, then pop it off). Take the trim ring off around the door handle. Rotate the cover on the window crank to expose the torx screw holding it in. Once you remove the top trim piece you will expose a screw, the same goes with the trim ring on the door handle. Take the torx screw out inside of the window crank. Once you have the screws taken out just pull straight up and the panel will come off.
Old 05-05-2003 | 11:06 AM
carson's Avatar
I appreciate the advice although I do not have a clip around the door handle nor can I find a torx screw for the window roller . Im thinking this may apply to your 2002 Xl not a 99XL?? Or is the bolt that hard to see?
Old 05-05-2003 | 02:06 PM
dgnr8's Avatar
http://www.alienmind.com/speaker_inst/
go down to "Now we tackle the front door." right on top of this picture:
Quick Reply: 99 XL door panel removal
