MOOSE Box Photos
Old 02-18-2004 | 11:55 PM
texasbikers's Avatar
MOOSE Box Photos
Here are some snaps of my Moose Music box and my 3 amps on the back wall.
https://www.f150online.com/galleries....cfm?gnum=3826
The MOOSE box ROCKS!
Old 02-19-2004 | 12:21 AM
Dupuis's Avatar
Looks good. I wish I had that kind of room behind my 04 seat!!
Old 02-19-2004 | 08:22 AM
warrior's Avatar
looks good. thanks for the pictures.
Old 02-19-2004 | 08:38 AM
TonyPTX's Avatar
texasbikers,
Did you drill through the rear cab wall to screw the amps in place? The obvious question then is, are the screw's showing on the outside side of the cab between the cab and bed? I was thinking about doing this, but didn't want to deal with the potential water leak paths.
Also, I'm guessing you cut out the section of plastic that was between the two access panel doors?
TonyPTX
Old 02-19-2004 | 11:26 AM
yes
Yes the screws do go through the back wall, a good dab of silicone prevents a leak. I did just cut the plastic with my handy dandy Jig Saw.
Yeah screws show, barely and frankly I don't care.
I do plan to remount them some day, maybe when the kids are all grown and out of the house...
It's all about the sound... !!!!
Patrick
Old 02-19-2004 | 11:51 AM
cgorris's Avatar
If you do not want to drill holes through the rear of the cab. You can silicone a piece of wood to the rear wall of the cab. Then use short screws to mount the amps to the wood piece.
Old 02-19-2004 | 11:59 AM
subbox's Avatar
Looks great...
If you do not want to screw into your cab, you can first carpet a board and stick it against the rear cab wall. You can use glue or even alot of velcro to make the board stay in place. The weight of the board will be on the floor,so you are just keeping the top of the board from falling forward.
Then just screw the amps to the board.
For a clean look, cut small holes in the board so you can tuck the wires behind the board too.
Andy
www.SUBBOX.net
Old 02-22-2004 | 12:28 PM
M_Brandl_'s Avatar
will you seats still fold forward with a seat lift (assuming the box was not under you seat.)
Old 02-22-2004 | 03:12 PM
yes
Yes, without the box the seats will flip forward.
Quick Reply: MOOSE Box Photos
