Need Help
Old 08-05-2000 | 06:26 PM
dragonboy's Avatar
Post Need Help
I have a dilema and need your expert advise in this matter, I noticed after I installed the Pioneer DEH-920R that the Polk and Pioneer speakers need help, the bass that this system is giving is making this speakers sound crapy, well lets not denigrate the speakers they are good, when playing instrumentals you can listen to minimal chirp but when i play a heavy bass music the speakers cant keep up with the system, so I decided to explore for a subwoofer and thought of the MTX but too expensive and take away too much space from the rear seats then I found this page but need your help find out if this will help the speakers (polk & pioneer); [img]//www.discountcarstereo.com/Clarion/psw160.htm[/img]
What do you think will it it help it??
Old 08-05-2000 | 06:28 PM
dragonboy's Avatar
Post
Sorry the page did not show up but would you please try this link, thanks.
Old 08-05-2000 | 07:08 PM
captainoblivious's Avatar
Post
your polk and pioneer speakers will sound much better when you get a sub to take away the lower frequencies from them.
If you want to spend money the MTX and Q-customs they make to fit under the seats are good, but pricey still. If you want decent bass without giving up room I'd go with either 2 8 in subs or a single 10 that has a shallow depth. If you go with 8's choose carefully because some 8 sound more like midbasses then sub.
But you can easily fit 2 8's or 10 under the seats and an amp without taking up much room. I've measured under my rear seat and it's roughly a 5 inch depth. So you would want a sub with about a 4 inch mounting depth.
You realy do have alot of options, just look around at diferent things and find out as much as possible. Take your time and plan carefully
black 97' x-cab 4x4, 5 speed 4.6, black westin nerf bars, 6 cd changer and a 12 premier sub, pilot ground searchers, borla SS split rear exhaust, K&N genII, bosch +4 plugs, superchip, flexalite electric fan, v-tech oval side window covers, IAS shocks
still to come: new spark plug wires, new rims and tires.
Old 08-05-2000 | 09:52 PM
dragonboy's Avatar
Thumbs up
Capt,
I got the point, thought I could get away with out paying for it, anyways just found this online store that have the MTX's lot more cheaper than Crutchfield, and thanks for your advise.
Old 08-06-2000 | 11:58 PM
Ford4Fun's Avatar
Post
Try some cross-overs, all they do is eliminate certin frequincies of sound. It would be a cheap solution to your problem.
Old 08-07-2000 | 03:03 AM
dragonboy's Avatar
Post
thanks again, checking the features that my H/U comes with theres a 2 way crossover, i'll try it and see,
Two-Way Crossover (HPF & LPF)
Front/Rear HPF (50/80/125Hz, -12dB/Oct.)
Sub-Out LPF (50/80/125Hz, -18dB/Oct.)
Sub-Out Level (-12dB to +12dB) and Phase Control
Old 08-07-2000 | 08:37 AM
Jolly_Green_Giant's Avatar
Post
Another thing you might consider is an amp. H/U power is natriously "dirty" even the more expensive H/U brands.
1998 F150 XLT, extended cab 3 door,Pacific Green, towing package, 4.6L V8, 3.55 LS,
Performance Mods
SUPERCHIP, K&N FIPK, Dual Exhaust (18" glasspack), Bosh Platinum +4 spark plugs
Apearance Mods
Lund deflector, Profile Windstream side window air deflectors, Prostripe silver multistripe, Diamond Plate Toolbox, Diamond Blue(HID) simulator Fog Lights, High output headlights (80watt low/ 100watt high)
Electronic Mods
Whistler Radar Dectector, Uniden Police Scanner, 29WX-ST Cobra CB Radio, with a Texas Star 100watt modulator and a Wilson 2000 Trucker antenna. A Clarion Security System with Keyless Entry,
Audio Mods
Kenwood KDC-6011 CD player/changer control head unit.
JL 10" sub-woofer
Fultron "Depth Charge" amp 200w max.
4, TR570-CX JL Audio Coaxial Speakers (factory location)
Old 08-07-2000 | 04:30 PM
dragonboy's Avatar
Post
Jolly,
I made the adjusments of the crossover and the sound is a bit more clear with the bass but as you said the power is not too clean, I'll be window shoping for a nice amp and woofer or woofers, by the way were did you install your woofer??
