Need help with front speakers.
Hey everyone,
Just purchased a pair of the Infinity Reference Series speakers.
This is going to be my first attempt at doing an audio install, so I figured speakers would be a good start because there isn't to much wiring involved.
So heres my situation: I popped off the grills over my 05 STX front speakers, and removed the stock ones. I noticed that the stock speakers have an adapter that the Infinity speakers do not.
I'm guessing I am going to have to cut that adapter off and solder the 2 wires on to the connections on the speakers?
Also, The drivers side has a red and light blue wire, and the passenger side has a green and white wire... how can I tell which wire to connect to which connection?
Thanks again in advance.
Awesome, thanks for the replies.
Made a quick trip over to wal-mart and picked up some connectors (i don't know if they're called spade or not).
Install went smoothly! Everything sounds great from these Reference speakers even on a mostly stock unit.
Quick question: Should I have the ball piece (I'm guessin' the tweeter), pointed up or down? It is adjustable.
[QUOTE=titansu]If you're gonna do something - don't go 1/2 assed. Stop by you're local Circuit City has an install shop - they're $11 for a pair.
Yeah,
I got mine at circuit city for $10 a pair. Made things alot easier and now I dont have to worry about them when I sell the truck. Just unplug the harnesses and plug back in the stockers.
Good luck,
TheGhost
Yeah,
Good luck,
TheGhost
