Patman03 box revisited
Well i pulled out my box in mid december due to rising theft rate in my area. While i had it out i planned to redo the box.
Last time the box was in the truck it had a cargo ratchet strap around it holding it together.
I started by replacing most of the screws from 1.25" to 1.5" screws
![](http://i21.photobucket.com/albums/b269/Patman03SprCrw/Fiberglassing/DSC03570.jpg)
Then i bought some fiberglassing materials and started experimenting...
First step is of course alot and alot of sanding
![](http://i21.photobucket.com/albums/b269/Patman03SprCrw/Fiberglassing/DSC03577.jpg)
![](http://i21.photobucket.com/albums/b269/Patman03SprCrw/Fiberglassing/DSC03579.jpg)
Then actually start glassin'
![](http://i21.photobucket.com/albums/b269/Patman03SprCrw/Fiberglassing/DSC03587.jpg)
![](http://i21.photobucket.com/albums/b269/Patman03SprCrw/Fiberglassing/DSC03597.jpg)
I fiberglassed the top and bottom and rear corners. still need to do the nose, but i was itching (litterally) to put the box in and see how it sounds.
![](http://i21.photobucket.com/albums/b269/Patman03SprCrw/Fiberglassing/DSC03608.jpg)
![](http://i21.photobucket.com/albums/b269/Patman03SprCrw/Fiberglassing/DSC03609.jpg)
I plan on doing front end and one more layer once weather warms up a little.
then im going to "kitty hair" it and get it ready for paint. I am gonna have it sprayed in gloss black and then cleared.
I want to do something nice with the area between the seats on the back wall. I think i might cut more and put a clear panel in and put the amp on a full rack in the wall....
-Patrick
liquid nails
but Bartak, the seams on my pieces werent perfect due to so many angles. Every panel on my box had to be tapered and angled to go together, so the glue can only do so much.
plus i apparently didnt put any screws holding the front bottom to the two sides.
Just a few pointers for the next time around.
1) Glass the inside of the box...far less sanding and work.
2) For the outside, you can run a router and a 1/2 roundover bit around the edges, then a very thin layer of body filler to fill the screw holes and seams. Sand that down nice and spray the whole box with high-build primer and block it out, then paint. It will be most beautiful, without a whole lot of work.
Otherwise, it looks like you got a good start. Oh, and next time, watch out for those polarities!! They'll get ya!
![lol](https://www.f150online.com/forums/images/smilies/lol.gif)
Lesson learned:
- Test, Test, Test,
- Dont be in a semi with bad weather
- Black is hot sometimes...
Originally Posted by Low_e_Red
I did that last night in a 2000 Volvo Semi. I hardwiring power for an XM Xpress, I was kinda in a rush as we were under tornado watches/ warnings (I saw one form pretty cool) but I saw white and black wires at cig, assumed white was positive and POOF! that sucker stunk bad.
Lesson learned:![lol](https://www.f150online.com/forums/images/smilies/lol.gif)
Lesson learned:
- Test, Test, Test,
It gets kinda difficult going from residential and commercial electrical (which I do everyday) to 12V. You gotta remember to swap what polarity black is around in your head.
I personally think it should be illegal for black to be hot in ANY 12V vehicle. I have seen it a couple of times myself, and if it werent for the "test, test, test", it would have stunk bad for me too!
It sucks. Im going to have to buy it probably... It lit up like normal, But damn seeing that white smoke just drift up wasnt fun.
![Roll Eyes (Sarcastic)](https://www.f150online.com/forums/images/smilies/rolleyes.gif)
yah well it looks like i burned up my headunit believe it or not. Got some 40amp fuses for the amp and it wouldnt come on. Probed for voltage at the amp on the remote wire and was getting .4 v then probed at the back of the headunit on the remote wire and was getting .3 v Tested the wire for resistance, came back .01 ohms. I jumped the remote wire from the ign wire on the harness and amp comes on just fine. Looks like i burned something internal on the headunit by reversing the polarity. oh well works just fine now, just rigged a little.
The box is fully fiberglassed with 2 layers all the way around, and it pounds. Still need to do the kitty hair and paint, but that will be several weeks from now.
