00 Conti Build
00 Conti Build
So, as always I try and shoot a few pics as I go.
System will consist of :
Headunit - Pioneer DEH-P880PRS
Front Stage - (hopefully) Dyn 342 Active
Rear Stage - Polk SR6500 Active (When needed...)
Subs - 2 Polk SR124
Mid/High Amps - 2 Eclipse XA4200
Sub Amp - Eclipse ZA1200
Processing - 2 RF 3Sixty.2
Wiring - Kicker S-Class
Deadening - (hopefully) Damp Pro 200sqft
Alarm - Viper 5901 Responder LC3
SR124 Arrival -
Subs - 2 Polk SR124
SR124 Arrival -
But Ill be able to turn rear spks off/on and I dont have much else to do with the SR6500....
Im doing it on my free days. Which will be tomorrow and monday. Dyns wont be here for a month or so.
But heres the 7901 pics:
It has a nice remote. A bit thicker than what I expected but I do like the "1 Mile range" and the 2way with the LCD. It charges via mini-USB (thats cool!) and can backlight to 7 different colors.
Install pics will be coming soon.
UPDATE: I have the SR12's hacked in (so no pics there) and are getting better and better as we go. That ZA already tore up a 100A ANL fuse. And getting 6.5's into the doors is going to be a BI*CH!!! I will probably have to cut up the map pocket and break out the glass.
So in the meantime I put the Eclipse 5x7's from my upcoming Explorer Build in. They arent bad for a set of PS's so high up in the door. And I will have to ground the RCA's as the Picofuse issue has found my radio.
The fact that you caught that out of everything proves "the dont ask dont tell rule" wrong....
I like everything except the grilles on the subs. They are fugly. The SRs look beautiful, dont cover them up with the bling!
I wouldnt normally cover subs up but these are my first trunkmounted subs. Everyother one I have had, I could watch and make sure that nothing would happen to it. These I cant and I kinda use my trunk. So, I dont mind the grills appearance. They stay. Thanks for the advice though.
I might just take the time and disassemble it. I hate Picofuses.
