What amp with 1 Image Dynamics 10"
Sweet! Focal's are VERY hard to beat... Like I said, take a good hard look at those Cadence amps, ask around, go to different forum boards etc. Those things are SUPER SOLID and will run anything you decide to install. Plus a 5 yr warranty is almost unheard of...
I have read some on the Cadence amps and I havent seen anyone not like them. So I think I will pull the trigger on these two. I only hope this system sounds a little better than my stock audiophile system....
I love how this snowballed. About 2 weeks ago I wanted to order a TomTom for my car and figured if I was going to spend 200 on that I mine as well spend an extra 200 and get a headunit with nav to avoid clutter. Then ironicly my rear speakers started to go out, and here we are now $2,300 later
Amp for Focal fronts ran @ 4 ohms
http://www.woofersetc.com/index.cfm?...roduct_ID=6027
Amp for 2 10 IDQ V3 ran @ 2 ohms.
http://www.woofersetc.com/index.cfm?...roduct_ID=6031
Yes, the ia9 is a beast and is more suited to running a those subs at a 2ohm load. From a flexability perspective, I'd run dual 4ohm subs so you can run them at 4ohms or 1ohm... I currently am running dual 2ohm subs and wish I had gone with dual 4's
But at 1 ohm, the iA7 will be fine with those subwoofers too if you want to save a few bucks. Plus the iA7 has a smaller footprint, should be easier to fit on the back wall of the truck.
