subs for a reg cab bench
Old 02-28-2002 | 04:28 PM
kysard's Avatar
Looking for advice or a diagram for building or buying a box for a reg cab with a bench seat. I don't want to raise the seat or loose any travel with the seat. I know this will put me with a small sub but I think small subs sound best anyway.
any links or advice?
Old 03-01-2002 | 09:13 PM
isaiah4031's Avatar
My box measures 1.32^3 ft for a single 12 (for now). mesures 13.75"h x 24"w x 11"db x9"dt. I did move the seat forward a notch. Not bad with only 200w.
a little less in depth and longer would work well for 2 10"s ported jl 10w3. maybe enuff for 3 sealed. hope this helps
Old 03-02-2002 | 03:16 PM
kysard's Avatar
thanks, I ordered some CDT 8's. says they work with .35 cuft enclosure.
Old 03-04-2002 | 10:03 PM
brokeagin's Avatar
If all you need is .35 cu. ft. of volume, the boxes should be really easy to make. I used the back wall of my cab for the back of my sub box out of fiberglass and plywood to make the front and inside. I am using Memphis subs that require .75 cu. ft. and I can still slide the seat all the way to the rear with no loss of leg room. E-mail me if you would like a link to a page I am working on that will give you a better idea of what I am talking about.
David
Quick Reply: subs for a reg cab bench
