Going lower build
Old 04-25-2010, 04:13 PM
coobies5's Avatar
nice pat
did i miss something on your bumper being painted?
  #32
Old 04-25-2010, 04:18 PM
Originally Posted by blackedoutV6
i want to do naughty things to the back end of your truck....
Thanks Travis
Saturday I notched the bottom of my bed where my diff housing was coming up too high, now my spring perches are bottoming out on the top of my notch on big bumps, those L leafs are soft, they are traveling 3" before they bottom out. Not sure if i should try and trim the top corners of my spring perches or just put my bump stops back in, or both.
See the dent?
Notched the bottom of the bed, primered it
Looking up, where spring perch tabs have hit the top of my notch
Spare tire ground clearance 5.5"
  #33
Old 04-25-2010, 08:58 PM
thejake1989's Avatar
looks sick pat. when you gonna finish up the front?
  #34
Old 04-25-2010, 09:36 PM
next couple of weeks, still need to order upper ball joints, and front shocks, I may get just the upper ball joints first and see how it rides and maybe wait a month for the shocks.
Rear isnt done, i need to figure out how to keep it from bottoming out on all the big bumps, and i need to install my rear L sway bar.
  #35
Old 04-25-2010, 09:38 PM
sounds good.
what about using the stock bump stop but cut down some?
  #36
So how much of the perch is hitting the top of the notch? Can you trim a little of both so you won't affect the strength of the notch?
  #37
Old 04-25-2010, 10:05 PM
Compare this one to my next one to see the effective drop that the L leafs gave me:
you can see in the pic above, the basic shape is of the perch is a W, only the outer tips are hitting at this point because they are the tallest.
I definitely will not be cutting the notch any.
I have a hole in the notch for mounting a bump stop, so ill probably use my trimmed L bumpstops for starters and see how that goes.
I have considered trimming the top tabs of the perch, but that is probably last resort.
  #38
Old 04-25-2010, 10:14 PM
Good thing is it's not hitting much,looks like around 1/4" or less.. If you do trim a little bit of both you can always reinforce the notch more.
  #39
Old 04-26-2010, 12:47 PM
SMOKEin's Avatar
look'n good
  #40
Old 04-26-2010, 03:13 PM
Originally Posted by coobies5
nice pat
Yah i got rearended last fall, see F150 vs Suburban
  #41
Old 04-26-2010, 07:49 PM
well bad news, the rear sway bar won't work with my truck being this low, guess its going in the classifieds....
I installed the bumpstops, its not really the permanent fix i am looking for b.c they are limiting my travel meaning a harsher ride, but it will for for a couple weeks until i can try something else.
  #42
Old 04-26-2010, 07:53 PM
coobies5's Avatar
oh yeah, i remember that thread, just didn't remember if you got it painted then or not.
as for the sway bar, notch your notch lol
  #43
Old 04-26-2010, 08:02 PM
Dnasty777's Avatar
What is the sway bar supposed to attach to?
  #44
Old 04-26-2010, 08:40 PM
end links that come down from the frame. The factory endlinks i have are too long. And there are brackets with bushings and an ubolt that mount to the axle.
http://www.nhtoc.com/vbforum/how-art...tall-pics.html
  #45
Old 05-09-2010, 10:00 PM
Here's how the rear sits
Had my first casualty tho, i was backing into a parking space and on the left side of the of the space was a gutter, so as i backed in, my left side sunk down into the concrete for runoff, and i bottomed out on the curb on the back side of the parking space
Before. check out those nasty UBJ angles
Stripped the frame, set the spindle and brakes to the side for now
Old upper and lower control arms, my upper ball joints were toast!
All back together (sway bar disconnected)
Sitting down, only got about 1" drop out of the 2" arms
Then i noticed the bumpstops were limiting travel at rest, so they got removed
With the bumpstops removed i got my full 2" drop from the arms
Then i noticed the sway bar endlinks were way too long, and leaning at a 45* angle towards the front of the truck, so the sway bar and links got removed
Bunch of parts in the bed of the truck so she's squatting, also this was before i removed the bumpstops
Still need to do my alignment, i got it as close as i could get it for just eyeballing it.
Other problems i still need to overcome, i'm rubbing the inside of the front tires at full lock on the top of the fender liner. Im hoping after the alignment the problem will be less severe.
Comments?
-Patrick
Quick Reply: Going lower build
