What are your plans for the sway bar? Are there shorter end links out there? Also how's the ride?
Probably just leave the sway bar off, if i were to use it, i'd need to move it back about 1" on the frame to line up with the mounts, and get some really short links, not worth it in the long run, a truck this low doesnt have much for a high center of gravity so i dont really need the swaybar. As for the ride i just circled the apartment complex to make sure i didnt have any major clunks or knocks before i drive it to work monday.
looks great pat. hope you dont plan to go over any speed bumps
other then the valence i should be able to clear speed bumps just fine. And as for the valence, ive got a plan for that
Originally Posted by coobies5
jealous
make my 4x4 close to that
heh you're better off getting a 2wd but we've already discussed this
