Difference in Cylinder Heads?
HI!... I launched a plug a few months ago. Probably due to I change plugs quite often, about 4 times a year. I launched the P/S front, so at least it was easy to get to. Took JMC and I about 35 minites to fix it with the head on the truck. We used a 9 thread TIME SERT. My new "03" FOX LAKE STAGE 2 heads have had all the sparkplug threads replaced with titanium TIME SERT's.
So.....
If you have a forced induction system on a 5.4, should you do the "Time Sert" or "Big Sert" as a form of preventive maintenance to all eight (8) sparkplug holes????
.....in other words......
I would like to do the Time Sert (or Big Sert?) to all eight (8) sparkplug holes, since the engine is on a stand with no intake mounted to it yet, but I might screw something up, if I remove the heads (removing front cover, timing chain, etc.).
However, until I saw Neal's post, I thought the blown plug issue was caused by the sparkplugs working loose or the use of anti-seize on the threads. Yet, if it can happen to Neal, that tells me that checking the tightness of the sparkplugs on a routine bases, is not enough to prevent this.
(Sorry cerucker, if this deviates from original thread issue)
http://www.timesert.com/
or
http://www.timesert.com/bigsert.html
and
http://www.timesert.com/FAQ.html
It is a "tap and die" operation. Most use it to install new sparkplug threads, where the originals were blown out or stripped. I would like to use this kit to increase the amount of threads in the 5.4 heads, from 4 threads to 7 or 8 threads.
You can do this with the heads bolted to the shortblock by somehow using grease to catch the metal shavings. Unsure, how to proceed, if you want to do this to all eight (8) sparkplug holes. Would be nice, to just remove the heads, but that means removing the front engine cover, removing the timing chain from the cam sprockets, getting new head gaskets, installing new head bolts and torquing them in the correct amount and sequence.............for iron horse, that might require too much skill. haha!
............what about applying some "blue" loctite to the threads instead?
or
and
Originally posted by cerucker
No problem, I just wanted to see how useful my extra set of heads was.
